Thread views: 308 View all threadsNext thread*Threaded Mode
davidebarlotti
2002/05/15 20:23
Modem ISA 14400 Reply to this post
I have read in the Online Order who is avaible a Modem ISA for the Sprinter. I think is for the use with Black Terminal program...
It's possible use a Standard ISA modem ?? If Yes at wich IRQ and adress ?? if this is possibile then it's ok also put a ISA serial port (with the correct IRQ and ADR) and a esternal modem or a null cable to a PC...
Re: Modem ISA 14400 new [re: davidebarlotti]Reply to this post
Yes, Sprinter can use a standard ISA (internal) modem. Black Cat Terminal not need setup of IRQ. If your modem has DIPs, to switch it in COM1.
davidebarlotti
2002/05/16 13:21
Re: Modem ISA 14400 new [re: Alex_Goryachev]Reply to this post
well, I want try to put a Serial ISA8bit card set to COM1
who I have.
I try to connect a esternal modem in serial port and
also with a null modem cable to PC.
2002/05/16 15:35
I read somewhere that internal ISA modems have similar operation to com port expansion cards. Would it also possible using an isa com port expansion card if i wanted to use a null modem cable or other rs232 peripherals?
PC<->Sprinter connection new [re: polardark]Reply to this post
We haven't ISA Com port expansion card and can't check this variant.
But we have plan to create PC<->Sprinter connection cable using LPT port, with software support, certainly.
I hope it will be done in summer.
davidebarlotti
2002/05/24 11:35
Re: Modem ISA 14400 new [re: polardark]Reply to this post
Hi, I have put a Multi IO 8bit in my Sprinter and a Serial Modem in COM1. I have try to use the Black Cat terminal bu the program dosn't start.. I have try to start from FC the file BTC.TRD with the Sprinter configurationt the system jump
to TRDOS but the (RAM) disk is empity...
I have also made a real trd disk but when load "boot" the system go to BASIC Spectrum... I have also made the directory im my hd C:/modem/download C:modem/upload c:modem/bads...
There is some user who use this program and can help to me ??
db/s4e
Did you check first slot (at the top) and second slot?
And did you saw any programm message?
Edited by Alex_Goryachev on 2002/05/24 12:17.
davidebarlotti
2002/05/24 13:39
I have put the card in the first slot (that more far away from the processor...)
no message...
But if you tests without modem and card the program
writes of the messages?
db/s4e
Try to put modem in another slot.
Programm can start without connected modem. In this case you will see message "Modem not found!!!"
davidebarlotti
2002/06/29 13:35
Hi,
I have made other tests with the modem after to have resolved the problems of the FDDonly some FD no good..).
Also in my Sprinter appears the message MODEM NON FOUND!!! PRESS ANY KET TO CONTINUE
(BTW. if I press any key don't continue but the system is'n hang because I hear the sound from audio when press the key...)
I have try With a ISA MODEM setting:
COM1 IRQ4
COM2 IRQ3
COM3 IRQ4
COM4 IRQ3
and in slot1 and slot2.
The modem is correctly powered from the bus because when
I reset the system I hear "click" from the internal speaker of the modem.
Other tips???
I try however the modem in a PC in order to assure that it is working.
